WEP key
ChrisJofeh
How do I learn the WEP key of my EE router?
1 ACCEPTED SOLUTION
@ChrisJofeh : Which EE router do you have (read label or post a pix)?
Login to your router. Then in the WiFi section you should be able to see your WiFi password in clear & change it if you like.
Northerner
Hi @ChrisJofeh
The password will be on the sticker/card which came with your router.
Thank you!
Thank you!
