on 05-03-2023 02:13 PM
Hi
I’m another one using their own Router. (Sorry 🙁)
I have a 900Mb/s Full Max installation and have an Asus ET12 Router Installed. It’s setup for PPPoE.
I have been limited to download speeds of c.400Mb/s and, until recently, assumed there was a problem with my connection. Openreach guy turned up and proved a much higher speed with the EE Smart Router (Unopened and never used). 600Mb/s.
I want to use the Asus router for its Mesh capabilities and range. (I need the range for 2 external cameras).
I’ve since read that PPPoE may be restricting my speeds but that’s outside my area of expertise.
Any ideas that might help me achieve the performance I’m hoping for?
Thank you!
on 05-03-2023 02:41 PM
@DaveH22 there is no issue using your own router, you do need to use PPOE to authenticate with EE, no idea where you would read it slows things down.
As for speeds, how are you testing and with what equipment?
on 05-03-2023 02:55 PM
Speedtest and a MacBook Pro. Also iPhone 14 Pro.
This is where I first read it. Similar scenario.
on 05-03-2023 03:04 PM
That article suggests switching off Smart Connect, nothing to do with PPOE.
Are you able to test over an ethernet connection?
on 05-03-2023 03:10 PM
Smart Connect is already off. Have also tested using an Ethernet connection to MacBook. Similar results. EE Smart Hub was significantly faster either way.
on 05-03-2023 03:19 PM
Try a wired speedtest, using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
on 05-03-2023 03:34 PM
Already done that. A Cat7 Ethernet cable plugged directly into USB Hub then into MacBook Pro
on 05-03-2023 03:37 PM
on 05-03-2023 04:14 PM
@DaveH22 Not sure what you mean by this. Did yu mean and the ONT?
Did you use the same ethernet cable between the ONT the routers? There have been examples of people using cables not able to support 1Gbps - either between the ONT and router, or router and laptop/PC.
on 05-03-2023 04:27 PM
I don’t have a cable of lower spec than Cat6.
My connection is :
USB C port on MacBook Pro
To Hub USB C Hub 7 in 1 HOPDAY USB C Adapter, USB C to HDMI Dual Monitor for Macbook Pro/Air,HP,Dell,Surface, Multiport USB C Docking Station (4K HDMI,100W PD,2 USB A 3.0,USB C 3.0,SD/TF Card Reader) https://amzn.eu/d/cuk6H6X
To Ethernet on Router
Same result as Wireless from iPhone
