Re: Broadband
Daio62
Same here even bought Erthernet cables no difference whatsoever. Ruins tge night especially weekends.
Daio62
Having issues but not for that length of time. Mines more buffering and sound.
@Daio62 : Welcome to EE's Home Broadband Forum.
How do I get such information. From what device? My iphone?
  You just spoke French to me. After buying 2 Erthernet cables and just now 2 WIFI extenders. When I use Netflix on my tv not fire stick it works fine. I own a 24 inch Polaroid TV my son who I bought 41 inch Polaroid is having buffering issues also he is righ aboutthe Routerin a tiny 2 bedroom house.
 I have a fire stick to add to my woes too. Also alexa took over my tv speaker without even a prompt.
I got the white square 🔳 box with the green circle 🟢 Router it's always green unless I switch it off. I can't even download apps on my tv their not there. I have the latest update as the tv 📺 is only 2 years old.
 I do notice the Mbps can drop significantly to 19Mbps to 58Mbps
Please email me taking in the fact that all this Broadband and Upper case letters mean nothing to me. DDSL blah blah blah
  I tried signing admin with  my password on back of Router but it kept refusing me warning I had only 5 tries.
  I do not enjoy winging what I suffering these many evenings is getting to me whole weekends I wanted to chill ruined or being only able to watch Netflix or Amozan because only them I have on my tv but I think that Polaroid issues not yours, I just do not know.
  I know I told the eager guy in EE store all I wanted was tv and console to work well they are not.
 I also noticed people stressing about fire sticks so using them as well is kind of time consuming and ssso frustrating.
  You assume, I think, that I have a computer 🖥 or ipad. All I have is a Samsung galaxy s21
  Now do I use your EE app to do what info you need or do I download another app to run speeds?
  Kevin Bacon I think is a bit like Boris Johnson will say anything as long as there's enough zeros after $£
  You'll have to excuse me frustration because Broadband is not what I thought its figity stressful time consuming keeps me awake so I'm a zombie with a bit of psychosis kicking in.
  Telling me to send info to this forum but to hide certain numbers to someone that's pretty new to it all. I guarantee some poor sod will send sensitive stuff.
  Well as you can see I'm up late again and got to be up at 630am so by for now.
1. is from your router; 2. & 3. are from those links.
Which router do you have?
  • Login to your Brightbox at http://192.168.1.1 as "admin" with the admin password on the label on the back of the router.
  • Login to your EE SH at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router.
