Hi
Kelbel861
Hi I need a new routa adaptor wire
Which wire? The 1 between the router & the phone socket or the 1 between the router & your PC?
Mustrum
Hi @Kelbel861  9you could call the Broadband Care Team, or just go to your favourite place and buy a new one. They are not expensive, and may be your quickest way to get a new one.
Assuming from what you have said it is the cable between the router and filter then a standard RJ11 is available from many local shops, see :
https://www.google.co.uk/search?q=rj11+cable&source=hp&ei=gAMFZIChCo2DgQa7hqvYCw&iflsig=AK50M_UAAAAA...
HTH
