23-11-2024 01:12 PM
Using landline to phone an 0330 number and constantly get the engaged tone but can get through on mobile.
Have tried phoning other 0330 numbers including EE and there's no problem. It's just one particular number, which is a utility company. Thank you for any ideas
23-11-2024 01:15 PM - edited 23-11-2024 01:17 PM
It's probably your landline withholds its Caller ID but the mobile doesn't. Some businesses refuse withheld callers. Try dialling '1470' in front of the no.
23-11-2024 01:18 PM
just tried that but 1570 gets the message 'not recognised' so I can't dial any further
23-11-2024 01:21 PM
@macca20211 Call EE CS 150 from your phone, and have them check it out for you.
23-11-2024 01:22 PM
I'll do that thank you
23-11-2024 01:24 PM
Sorry, I misremembered! It's '1470'.
23-11-2024 01:40 PM
the CS adviser said try 1470 before the number but still get the engaged tone, so maybe I'll change utility companies!!
23-11-2024 01:43 PM - edited 23-11-2024 01:45 PM
Which utility is it & their no.?
23-11-2024 01:43 PM
sorry my fault, you said 1470 and I dialled 1570. Have now tried 1470 and 1280 but with either prefix the number is still engaged. Thank you anyway.
23-11-2024 01:44 PM
Not your mistake! I put '1570' in my original post before I corrected it.
