Using EE Smart Hub with a TP-Link Deco Mesh setup
BonhardBeej
Hi all,
First up, apologies, as I know these type of questions have been posted many times, although I am somewhat confused with the range of answers. Hoping that XRaySpex can maybe provide me with a conlcuding answer as to the way forward.
I won't go into the reasons as to why I am installing a TP-Link Deco M9 Mesh System, sufficed to say I live in an old stone-build farm property. I would like to continue to use the EE Smart Hub, although forcing it into acting as a Modem only, which I would then plug up with my first TP-Link node. I have seen many people stating that this cannot be done, and then some saying it can, and then some contradicting themselves.
I have a fibre plan with EE, although the fibre is only to the box down in the village, which is then standard copper up to the Farmhouse, about 500 - 600 yards up the road, so I am on ADSL. I get between 47 and 40Mb download, which believe me is good for my rural area, and acceptable to us for what we need to do. My plan is to switch off the WiFi in the Smart Hub config pages, and do the same with the DHCP. Cannot actually switch off NAT, as there is no option for this, although I do not have any Port Forwarding setup anyway, so that shouldn't be a problem.
I called EE Broadband technical help this morning, and a chap named Paul told me to excatly the same as I have decribed above, and all would be well in the world. But based on the feedbacks I have read on this and other forums, I am looking for that warm to hot feeling that what I intend to do is correct, acceptable, and wil work.
Thanks so much in advance for any help you lovely people can offer up.
30 REPLIES 30
MARViN2003
Yes, that's working as it should, you have the Smart hub IP range that's needed for any wired items (I have my gaming desktop wired directly to the smart hub) and the second IP range is used by the deco mesh.
The only downside is my wired PC cannot print to my printer via wifi (as it's on a different network)
