Upload speeds
JMW1970
Hi all
I have FTTC whilst desperately waiting for FTTP being built in my area 'in the next 12 months'.
Over Christmas I had numerous dropouts and my line (assumedly by DLM) was restricted and I lost a lot of my down and upload speeds. There was no expalnation for the dropouts and no fault found. The download speed has recovered but my upload is stuck at 3.6, which is unusable and causing issues. I was at 6.9 for over a year and according to my VDSL stats the line is capable of 7.1. I use a Draytek Vigor 130 into an Asus router.
According to the Draytek, my far SNR is 9db, which I assume is limited my upload sync.
Can this be fixed with a line reset? EE techs on the phone state my speed is within the guarantee for my line, but as I had almost double that speed until the dropouts I would really like it back.
Leanne_T
Sorry for all the confusion this evening @JMW1970 I hope that is all sorted now and if you have any concerns for any images please use the 'report post' option and one of the mod's will help you out.
If you need help with the broadband speeds, our technical support team will be happy to look into this for you if you get back in touch here.
25 REPLIES 25
  • For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs. Also post the Home > Status page.
2. Try a speedtest, preferably wired using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
Hi XRaySpeX
Thanks for your offer to assist.
Router stats from the Vigor:
  ---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
   Running Mode            :      17A       State                : SHOWTIME
   DS Actual Rate          : 54997000 bps   US Actual Rate       :  3693000 bps
   DS Attainable Rate      : 64544476 bps   US Attainable Rate   :  7107900 bps
   DS Path Mode            :        Fast    US Path Mode         :        Fast
   DS Interleave Depth     :        1       US Interleave Depth  :        1
   NE Current Attenuation  :       21 dB    Cur SNR Margin       :        4  dB
   DS actual PSD           :     5. 5 dB    US actual PSD        :     5. 7  dB
   NE CRC Count            :        2       FE CRC Count         :    10029
   NE ES Count             :        1       FE  ES Count         :     9517
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        3
   ITU Version[0]          : fe004452       ITU Version[1]       : 41590000
   VDSL Firmware Version   : 05-07-06-0D-01-07   [with Vectoring support]
   Power Management Mode   : DSL_G997_PMS_L0
   Test Mode               : DISABLE
  -------------------------------- ATU-C Info ---------------------------------
   Far Current Attenuation :       29 dB    Far SNR Margin       :        9  dB
   CO ITU Version[0]       : b5004946       CO ITU Version[1]    : 544eb206
   DSLAM CHIPSET VENDOR    : < IFTN >
________________________________________________________________________
I do not have a phone line so can't check the phone line stats on the BT Wholesale checker.
Speed test through ethernet connection result: https://www.thinkbroadband.com/assets/speedtest/1767880008562554855.png
Thanks again for your help
Jeff
Please use the Address Checker for the BT Wholesale Checker.
Apologies XRaySpeX, here they are:
[image edited to remove top line]
Locate the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws or press tabs) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets in the home even if unused? Are there any wires connected to back of faceplate of master socket?
Reboot the router & plug it into the test socket using a DSL dangly micro-filter. Post the full router stats & System Uptime when plugged into test socket.
Is the issue any better?
Hi
I have a Master Socket 5C, so have done as advised. No wires connect to back of the faceplate and there are no extensions in the house nor any phone plugged into the Master socket.
Stats after reboot with modem connected directly to the Master socket with a filter. Second one shows up time of 2 minutes. No change to sync rates.
@JMW1970 Please be careful what you post up on the Forum, displaying your address is just not good best to blank or hide the details! The speed test below is also very good and will give you a lot off detail on both the up/down speeds and what is going one with both.
https://speed.cloudflare.com/
Hi Jim
 Thanks for the tip, but I just double checked and my address is not listed on the BT check I posted. It just said ‘address’ and the town I live in.
Leanne_T
Hi @JMW1970
I believed a house number was showing and I removed this to be safe, if you can add this again and remove the first line above the box so no details are showing this would be great. If this was not your address details, I am sorry you can upload this again 🙂
Edit: I have added this image back now as no address details were showing and apologise for any confusion.
