Unable to port forward
Daniel2024
Hello,
I have been unable to port forward on a EE Smart Hub running from VDSL. I have ran a netscan and i see a few ports open that are not configurated on my hub's firewall. (8085, 443, 22661)
Server is connected via ethernet to the hub, Static IP address has been configured in both Linux and in the routers settings.
I have tried to port forward and disable the firewall, neither helped (Firewall is enabled again now)
I have tried DMZ, didn't work either.
Yes the server is currently running, has a active link to the router and is hosting services that are accessable both locally and on my other network (Server has a dual 1gig NIC)
Does anyone have any information i could try.
Thank you
Kind Regards,
Dan
Show the Port Forwarding settings of the router that you've tried.
