Total chaos switching BT to EE
EEE-101
When I spoke to BT about the slowness (sub guarantee) of my broadband, the 'guide' suggested I upgrade to a new contract with EE. With an upgrade to 1GB internet and a first three months reduction on a 24m contract. So I did.
It's been a nightmare since. Wildly inconsistent broadband speeds - some as low as 20mbps and frequent drop outs - even with three boosters. After about 15 calls they identified the issue as the ONT box had been installed in the basement by a BT engineer (before I moved in). I had mentioned this before. So EE agreed to book an appointment to move the ONT free of charge. It was pretty quick and they sent me an email the day before confirming the appointment slot (3 hrs) and asking me to be in. So I stayed home from work and waited.
No one turned up and no one called.
I then called EE and was passed from department to department (on phone for an hour) before someone picked it up from BT TECH TEAM - who had been given zero background - he just answered a phone and I was on the other line. He checked the system and you could hear his confusion - he said there were 'red lights' all over my account and that it'd take him a while to understand what had happened. He called back and explained that a BT TV engineer had been booked from BT QUBE and was clearly a no show. To his credit he said he'd get to the bottom of it and call me back the next day and he did so. But he said that they couldn't book a new appointment as the existing appointment was 'still open' so he'd have to wait til after the weekend. He then called after the weekend and said that whilst it would be sorted it'd take 2 weeks for someone to come.
I want to stress that after being passed around with no one taking any responsibility - David from BT TECH team has been brilliant and clearly done all he can. The first time he picked up the phone he was apologetic and said 'don't worry I will personally stay on this until it is sorted'. He always said when he'd call and always called when he said. I can't speak highly enough of the way he's conducted himself. But the end result is still poor.
It feels like there is a total disconnect between BT and EE - maybe one is front end and the other is back end now? But the worrying thing is that customers are the ones paying. Both me and my wife work a lot from home and this is hurting our businesses and I am paying for super fast 1gb broadband and have something unworkable. Surely someone (more senior) should be in touch with me to acknowledge this isn't good enough and set out how they are going to fix - and to just keep paying and wait another 2 weeks isn't acceptable. To this end I asked David if his manager could call me this afternoon and he has just called to say he will. I will report back how I get on.
7 REPLIES 7
Maestro
Maestro
@EEE-101 If you are having this all done, then the ideal position of the EE Router or BT one if that is what you still have is central position in the home, the ONT does not have to be in this position and there are some restrictions on what the install team for the ONT are prepared to do, but as the supplied cable which connects from the Router to the ONT is quite short that somewhat defines were it goes, ONT needs to be close to power, and as both devices need power look at your positioning, the fibre is delicate and installers like to keep it as short as possible to have it less likely to be damaged. At least you appear to have the ear of someone helping you as much as they can.👍
Thanks Jim - appreciate the help. OK, so if they come out (still haven't heard back form the manager!) - I guess from what you're saying - if there's a way to connect to the ONT in the basement but with the hub (router) directly above (in the living room) then that could solve things. The issue is this would mean drilling a hole through the floorboards and feeding the cable up - whilst I'd be very happy for this to be done, I'm not sure the engineer / installer would be prepared to do this ... so assuming they'll go back to the entry point outside the house and just drill through the wall to the other side of the living room.... (currently I think the fibre optic cable feeds under the house through an old unused dryer vent!)
@EEE-101 The cable that connects the EE Router to the ONT is a CAT5e Ethernet cable, that is all that is required to get the Router up to the area central that you need, if you look on amazon, you will see pre-made lengths of this cable that can be purchased if this would be the easier option. With pre-made unfortunate the plug is way bigger than the cable, so hole size to push the cable up via the floor, your decision to make. Failing that engineer to move the ONT from current position to were you want it and couple power sockets nearby for the ONT and the Router.
Msaladays
So frustrating ☹️
EEE-101
Promised I'd get back when the manager got in touch. This happened yesterday. It started with a confirmation that it would be two weeks until an engineer could attend for a ONT relocation. It's clear that what this means is effectively them treating me like a new customer and booking an engineer to do a new instal. Which I presume will mean starting again and just running a line into the living room from outside (the obvious and easy solution).
As you'd expect I objected to 2 weeks which I was then told was standard to which I said - yes, but that doesn't take into account the fact that I was booked in a week ago (no show), having waited two weeks meaning it was in fact 5 weeks. She was apologetic and accepted that this wasn't ideal but said there was nothing she could do on the timing. Accepting this I said that the fact remained that I was paying for a sub-optimal broadband service for an extended period as a result of their failure which at least needed to be remedied. At this point I was offered a credit to cover this period as a discretionary solution. So - not ideal but at least I've been listened to and they've accepted the issue and responded. Which is sometimes all we want right? Will report back in 2 weeks when it is hopefully all resolved and I have lightening fast and stable broadband 🤔
@EEE-101 And with this all re located keep in mind that you may not need that many boosters to get your wi-fi around every were you need, to many boosters can be as much of an issue if they do not play nice with each other and the router. Copied some info link below for you.👍
https://www.howtogeek.com/802557/mesh-router-mistakes-to-avoid/
Matt_124
Glad you've got an Openreach engineer booked to come out and sort it.
An important distinction to be made on the timing is that the Openreach engineers only work on behalf of BT/EE as well as all other Internet service providers using their infrastructure.
This essentially means that no one can influence their appointment availability even though they are often referred to as "BT engineers" and even though Openreach is part of the wider BT Group. It operates as an entirely separate entity for competition reasons. They are not allowed to show any priority to particular providers or customers and hence a specific process is used to book these appointments so that there is equal levels of service for all ISPs.
