Third party router login details!
truewraith66666
Does anyone know pppoe username details I have to put in when we m using a third party router for my EE broadband while I wait for my new one from EE. Using tplink but orange light with no internet as I can't get past.tyvm for any help
22 REPLIES 22
EE does allow the use of 3rd-party routers. However they may only investigate any issues until you put the supplied EE router back. In Using & Configuring a Third Party Router you'll find everything you need to set up your router incl. the BB PPPoE creds. which are now the same as BT's.
Thanks, tried putting in
bthomehub@btbroadband.com
And pass:  BT
But won't connect at all
@truewraith66666   which broadband service do you have, is it via an ONT or your phone line? Is it live yet?
What model is your TP Link?
Full fibre gig 700mb EE and my smart hub 2 is faulty and I'm waiting for new one but acquired a third party one called to link AXE5400
that should work OK, I would check the other settings, but maybe it is not the router that is faulty..
How is the ONT, are the right lights on?
Is that the white open reach box. If so 3 green lights.
I can't work out what is blocking it lol
Brilliant Contributor
@truewraith66666 You are using the settings in the ipV4 setup and not for ipV6?
@truewraith66666  if you can post a pic of the WAN setup page, maybe we can spot something.
But do remember the fault may not be the router.
