Thinking of Migrating BB to EE
L8Again
Valued Contributor
Valued Contributor
I currently have a FTTP connection with a BTW reseller/Openreach Network. I connect via a Fritz!box (Wifi6)  with a Fritz!WLAN mesh, and  I have static IPs (v4 and v6). My VOIP connection is with AAISP.
I am thinking of moving to a 900Mbps service which with EE would cost me £15/month less than if I upgraded with my present IP. CS with my present IP has been exceptional and apart from a 10 day loss of service due to an erroneous BTW cease order, my line is performing well.
What service differences might I expect to see with EE broadband? I am not a fan of 2 year contracts which is something that is high on my concerns list.
I would be grateful for any thought/input.
Maestro
Maestro
@L8Again If you do not like 24 months then do the 12 month at higher cost to yourself, NO fixed IP from EE for either part off the PPPoe signal, and all off the restrictions for DV Landline that you do not need to worry about with your VOIP service, EE TV potential issues if used, and customer service is a wait and see.!
EE provide no static public IPs if that's what you have with AAISP.
Profile closed
Not applicable
@L8Again
Cannot speak to the tech, only to the experience.
My advice; if you’re happy with what you’ve got, pony up and stay where you are.
https://uk.trustpilot.com/review/ee.co.uk
