on 26-08-2024 02:52 PM
on 26-08-2024 02:53 PM
I switched from BT to EE and I would feel no different. It’s been two months now and I’m fed up. I can’t watch any program without a constantly buffering.
i want to go back to BT. Is this possible?
on 26-08-2024 03:01 PM
@NettieLondon : Which EE BB plan are you on? What EE router do you have?
on 27-08-2024 12:08 PM
on 27-08-2024 12:14 PM
Hiya
I have the Smart hub SH31B model F5394-CP EE
I Am on the Fibre 67 essentials Plan.
Most of the time it kept buffering every couple of minutes. So frustrating!
When I went into the app it would try and ImProve it and then fine for few minutes then again buffering . And this is on bbc iPlayer! 🤦🏽♀️
I never had this problem with BT and am regretting switching to EE.
If you can help that would be great.
thanks
on 27-08-2024 12:17 PM
on 27-08-2024 02:01 PM
on 27-08-2024 02:30 PM
Hello
i dont know why only half the message below reached you..
1) when you say log in and find advanced settings sharer are you talking about? The EE app on my mobile? I do t see anything as advanced settings..
could someone please call me?
also tried to reloomat broadband and received this message
Hi, EE here. Has your broadband connection improved after the checks and restart of your router? If yes, you can ignore this message. If not, reply with the word CALLBACK between the hours of 8am to 8pm on weekdays and 8am to 7.45pm on weekends and we will aim to call you within 20 minutes.
when I wrote ‘CALLBACK’ and hit send it’s giving my me an error for delivery.
why isn’t anything working EE?
Please can someone either fix this get me back on BT? am really fed up of this.
thanks
on 27-08-2024 02:31 PM
That's not all I asked for.
4. Doubt an Ethernet cable will help you.
on 27-08-2024 03:11 PM
Hello,
the stuff you asked for i tried to paste it in from my mobile and it doesn't work.
1) was that advanced settings on my smart hub when i log into the app on my mobile? or somewhere else.
2) i managed to get a picture but it woudln't let me add it on here
3) couldn't get the address checking working with or without the postcode.
Apologies I am not very tech savvy so not totally clear if i am looking in the right place or understood what you have asked for.
Also when I last tried calling EE the guy says to me its my TV! an i should change my tv as there is nothing wrong with the router. to which i pointed out i didn't have any issues with BT, and i was told that my broadband would not be affected if i switched to EE, and how can they expect me to go and buy a new tv!? thats ridiculous.
occasionally when i do the speed test via the EE app it says things could improve on then suddenly it starts working for sometime and is clear.
i just want to go back to BT.
