24-01-2024 05:14 PM
I used to be a BT customer, however switched to EE in October 23. Had no problems with EE until now. My router is connected however on my mobile the WiFi just shows as " connected without internet" I have a set up direct debit with EE so why they not giving Internet?
24-01-2024 05:30 PM
@Jm951 you are not giving us much to go on here.
Which EE service have you opted for, what lights are on the router, and do you have internet access via any other device connected to the router?
24-01-2024 06:06 PM
Just broadband. There's a green light on my router and no I don't have access on any other device.
24-01-2024 06:17 PM
@Jm951 I suggest you give the Broadband Care Team a call.
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
From your EE mobile
150
From any other phone
0330 123 1105
Calls are free from an EE number. Charges may apply if you call from another network.
24-01-2024 07:08 PM
Login to the router & look at the Advanced > Broadband page & check whether its Status = Connected & what Down/Upstream speeds are showing.
