28-03-2023 01:51 PM
I have the latest EE Router.
I'd really like to know the technical specs.
Specifically the number of antennae on each band and the dbi.
Does anyone have this or could they point me at somewhere?
26-06-2023 10:54 AM
"The Brightbox 2 is functionally far stronger the than the EE Smart Hubs/Routers, like multiple SSIDs, VLANs & guest networks and better Access Control. I should stick with it. I have!"
I think I'm going to and see how it goes, yes; do you know if there are any other considerations to 'prep' the BB2 for a fibre setup other than to set the broadband type from adsl to either fibre or auto-switching, which I've already done? Shouldn't have thought so but thought I'd check as I've just had an sms asking to confirm my router is ready.
26-06-2023 01:54 PM
No, it should all be auto.
