TP Link Archer C80 wont connect to network
stewsmith1
Hi, sorry if this is a common question but haven't been able to find a solution. Recently bought a TP Link Archer C80 to replace EE smart hub. When I plug it in it to the wall it isn't able to get internet.
I've configured the PPPoE settings. My old router connected with a phone line whereas this one uses a WAN port.
Mustrum
@stewsmith1  alas you appear to have bought the wrong router. The EE Smart Hub is a combined modem and Router, whereas the TP Link is just a router.
It seems you need a ADSL.VDSL conbined roter.
Mustrum
Community Hero
Community Hero
@stewsmith1 If you are still connecting the router to a OR Master Phone socket then the router you need from Tp-Link is the Archer VX1800v model, was recommended somewhere and do believe that it worked out and connected fine, but you can search for the posting if you wish. The model you have is designed to connect to a FF OR via the ONT installed modem.
Lowest cost is the Tp-Link Vr400
TP-Link AC1200 Wireless Dual Band VDSL/ADSL Modem Router for Phone Line Connections (BT Infinity, Ta...
