Synology Issues - again
Arcadash
Hoping for a bit of assistance. Have been sent a new EE router. The old BT router allowed my Synology to set the port forwarding rules perfectly.
Like others, I am unable to get port 80 set on the router to access a small web page over the net.
I can configure the management port on the Synology and Router as nnnn and it tests OK
Trying to set port 80, fails. UPnP is set to ON, but it doesn't seem to work.
So what is the name of the router I should be searching for as it doesn't appear in the Synology list.
10 REPLIES 10
Mustrum
@daz_2000   what router do you have? And what have you done so far?
The Smart Hub plus does have issues with UPNP, but manualy settings ports should work.
