12-06-2024 12:17 PM
Hello. I was on BT Full Fibre 900 and switched to EE full fibre which is slightly faster and cheaper. I did this on the BT website. I received my EE router this morning. My question is, do I just connect the EE router and I am good to go? Can I use the cables already connected to the BT Home HUB 2? (Ethernet cable, power cable and fibre optic cable). Thanks in advance.
12-06-2024 12:25 PM
@joec1985 The answer is yes, you will have to connect to the new router SSID and its password, unless you set it up to match with your existing BT values, depends on what you want to do. Is the new EE service active yet, if not it will just connect to your BT at present. Hope that you do not have any App issues with the change over BT/EE. HTH
12-06-2024 03:49 PM
Sorted.
12-06-2024 07:51 PM
@joec1985 Hold onto your BT Smarthub2 for a couple of weeks, until you are happy with everything....
