Speed across network
spellfast59
I've got 900mb/s broadband and I'm getting that from the router and across wifi. However my AV equipment is linked to  a switch - Netgear GS308 Gigabit . Netflix says I'm getting 130Mb/s from the EE hub Pro and an android tv box around 11mb/s. I thought given the gigabit switch and the fact that i've got the ethernet ports linked by cat 6 cabling I should get full speed. Where am I going wrong? Am I expecting the impossible or is it my ethernet fly leads from the switch or what? Appreciate any help!!!
Maestro
Maestro
@spellfast59 The reported speed for the two devices will be correct, as a required measured speed to them, you may also find that they have possibly a 10Mb/s or a 100Mb/s Ethernet ports on them! You can speed test each cable end plugging into the two devices if you have an Gb/s Ethernet Laptop and run a speed test through that all the way back through the switch to the EE Router and onwards, that will prove everything out for you!
