Smarthub 2 will not connect to EE app
v6villan
Valued Contributor
Valued Contributor
Hi
Moved across to 500mb EE  broadband from the equivalent  BT 500 mb plan on 31st January
Still using my BT smart hub 2  . I paired the smart hub to my EE app so I could  use WiFi controls and do speed tests via the EE app. Worked fine when I used it a week or so ago. I see the android version  of the app was updated on 2nd Feb.
Went to do a speed test from the EE app today and was asked to pair my hub again. So scanned the QR code again
Was then greeted by a screen saying .You've already  saved these details . It brings up this message constantly.It wont allow me to pair the  hub again. So now after working for a few days I can't access Wifi controls  or conduct a speed test via the EE app .  Tried re pairing the smarthub 2 by scanning the QR code on the hub and manually adding.  Won't work either way, also unistalled  and reinstalled  the app  & reset smart hub.  Nothing fixes  it
This all worked perfectly  when with  BT, using their app
Been on phone for around 2 hours  . Got absolutely nowhere .
Seriously thinking  of using 14 day cooling off. The app is poor.
Any ideas how to fix would be appreciated
Justin
7 REPLIES 7
Neil-O
Former EE Employee
Hi @v6villan I'm sorry that you're experiencing problems with the app, did you try a factory reset of Hub or a turn off and on?
Neil
v6villan
Valued Contributor
Valued Contributor
Hi ,yeah as per my original post. I reset hub and unistalled and reinstalled the app.My smart hub 2 was paired with the EE app  but stopped working . Not sure if this  was after the last update to the EE app on 2nd Feb.
When  I pair it again  it says it is already  paired ,  but then when I go to WiFi controls  etc it asks me to pair my router again.
Realised yesterday  that if I use my old BT app I  can do speed tests  and use WiFi controls.  Essentially the things I should be able to do on the EE ap
This is a fault EE end not mine, been told they have issues  with the EE app and customers  who already have an EE  account for mobile  phone etc.  Seems an issue when they move broadband  from BT to EE. Wish I'd have stayed with BT  as their app worked as it should.
Got an open  ticket but not hopeful it will be fixed as reading of others with same issue ,and been like it for months
Simonk243
I am having the exact same problem trying to link my EE app to the EE smart hub 2.  Spoken to technical support but noone seems to be able to help.  Regretting switching from BT broadband to EE broadband.  Ticket raised and now awaiting a call back.  Also when our hub arrived he had no cables, so I had to use the ones that came with the BT hub.
@Simonk243 : EE doesn't have a Smart Hub 2; BT does. EE's is the Smart Hub Plus. Which is it?
Ewan15
Skilled Contributor
Skilled Contributor
If you are Using a BT Smart Hub 2 use the MY BT App
If you are using an EE Smart Hub Plus use the MY EE App
bunnyduracell85
Dud you get it resolved I'm having same problem
Peter_W
Good morning @bunnyduracell85.
Welcome to the EE Community 😊
Like the OP, did you also move from BT and are still using the Smart Hub 2, or are you using a new EE branded hub?
Have you had a chance to try fully resetting your hub and reinstalling the app like @Neil-O recommended too?
Peter
