on 14-08-2024 11:59 PM
Hi all. Simple question.
If I wanted to get rid of my smart hub white ee router altogether and replace it with a third party router is this possible?
I have the small box on the wall with thr fibre coming in which then connects to the back of the smart hub via ethernet cable.
on 15-08-2024 12:54 AM
Hey @djmat56 that would not be a problem, EE even have a handy help page with all the info you need to do so. Just make sure you get the right type of router.
https://ee.co.uk/help/broadband/getting-started/using-and-configuring-a-third-party-router
on 15-08-2024 01:14 AM
The white EE router is the Smart Router. You may replace it with practicably any router that has a WAN Ethernet port for its BB input..
