Smart Wifi
chrishyper1
Hi
Received my new booster today ready for my FTTH install tomorrow im currently still connected to the FTTC connection and i thought id set up my new booster can the aqua light in the middle be turned off as this will be going in my bedroom
Eddy2760
Expert Contributor
Expert Contributor
Hey 👋
hoe you have managed to turn the light off on your smart WiFi plus extender.
If not you am an access the light settings for your devices via the Hub manager page by opening up a web/safari page and typing in
192.168.1.254
When the page has loaded scroll down to the 7th panel, hub light control, you should be able to run the lights off there.
hope this helps 👌👌
Eddy
wgwright
Expert Contributor
Expert Contributor
You can turn it off in the Hub settings on the EE App
Eddy2760
Expert Contributor
Expert Contributor
Hey 👋
192.168.1.254
hope this helps 👌👌
Eddy
Like so:
Hub Light:Capture.JPG
 WiFi Extender Light:
Home > Advanced settings > Advanced wireless > WiFi Extenders
