Smart WiFi not connecting orange flashlight
Options
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-05-2024 10:01 PM
Options
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
12-05-2024 10:03 AM
Hi @K338 I'm sorry about that, please can you try resetting the Smart wifi and reconnect it to your Hub via ethernet?
- Move the Smart WiFi Device next to your Hub
- Connect the power lead and switch the Smart WiFi Device on
- Carry out a factory reset of the Smart WiFi Device by pressing a pin into the small hole, holding down the button for 12 seconds
- Wait 2 minutes for the factory reset to complete
- Reboot the Hub by turning it off for 30 seconds then switching it back on
- Connect the Smart WiFi Device to the Hub (try to avoid connecting it to port 4) using the supplied Ethernet cable
- Wait 2-3 mins for the Smart WiFi Device light and Hub light to start up and connect
Reply and let me know if that helps.
Neil
Related Content
- No broadband connection in Broadband & Landline
- 2 x EE Home Phone Adapters, neither contect to hub. in Broadband & Landline
- Broadband Router not connecting - constantly flashing orange! in Broadband & Landline
- My modem just arrived but I can't connect to the internet. The orange light flas in Broadband & Landline
- WiFi booster not connecting in Broadband & Landline
