Cannot manage wifi in app and booster not connecting wireless (blinking orange)
Pinq86
Hi all!
Day 1 of migrating from BT. Hub is aqua blue have internet connection but in the EE it does not allow me  to "manage wifi".  Tried install, uninstall, use 3 mobile phones logging in to EE account, turn hub on/off, factory reset, broadband linked. Nothing works still cannot "manage wifi" and is stuck to "preparing for update".
Moreover, booster turned aqua blue using yellow cable plugged into the hub. However, when turned off and moved to living room all I havr is blinking orange, it seems it does not connect wirelessly.
Seriously thinking of cancelling and moving back to BT.
Rach_H
Hi @Pinq86,
Welcome to the Community!
We want to make staying in control of your account as straightforward as possible, so I'm sorry to hear about the trouble you're having. If you reach out to our team they will be happy to check your account settings, and make sure this is set up as it should be.
Rach
Rach_H
Hi @Pinq86,
Rach
Maestro
Maestro
@Pinq86 Smart wireless is not connected with the flashing Orange, see the help below! Try leaving it connected longer with the cable, then in the same room once you disconnect to see if the wireless wifi connection grabs it! May take a few hours to do so.
https://ee.co.uk/help/broadband/getting-started/setting-up-smart-wifi
https://ee.co.uk/help/broadband/getting-started/setting-up-wifi-extender
https://ee.co.uk/help/broadband/fix-problem/fix-problems-with-smart-wifi
