Fiber and Copper cConnected At Same Time
Aspie10
I have just had fiber 900mbs.
but from the telephone pole. The engineer. Did not take away the copper drop line
since first week until now my speed is showed to on
it shoes 924mbs.  117mbs.  But in the house From hub to computer is 264mbs. 78mbs
from 12 of June  until now ee. Can only take to the hub
my last speed copper was from hub. 79mbs and 19mbs up fiber 67 but copper vdsl. That setup I had for 5 years no issues both wireless and Lan
so I have read fiber / copper should not be hooked up together.    Anyone else have the same problem with telegraph pole dual connecting live.
@Aspie10 : No, they're not hooked up together but sometimes when installing Full Fibre the eng. does not bother to remove the copper line. They each lead to separate terminals into the home, ONT for FTTP or master phone socket for FTTC & so are isolated from each other. You may find, should you put a router on it, that the FTTC BB continues for a few days/weeks.
Have you run the speed test in the EE app? That will not only measure the raw BB connection speeds you are getting at the router as well as speeds to the device from which you are testing.
Maestro
Maestro
@Aspie10 Not sure how you are seeing or trying to measure but if that is what you have, and is a wireless wifi connected device,
it shoes 924mbs.  117mbs. ""This will be the speed to the EE Hub delivered over the Fibre connection""
 But in the house From hub to computer is 264mbs. 78mbs ""This will be the speed from the EE Hub to your Device and as you say that may just be as good as this device gets speed wise""
Your copper line will be dead for a Broadband Connected feed.
