Smart WiFi Discs: Multiple Discs
RGMS
We have three discs as the hub is in one corner of the property. Disc 1 is paired with the hub. Disc 2 is paired with Disc 1. Disc 3 is paired with Disc 2. Is this correct or does every disc need to be paired directly with the hub?
1 ACCEPTED SOLUTION
Ali_A
@RGMS
Daisy chaining the discs is not recommended, as this slows down the response time and speeds the further along the chain you are. i.e. anything connected to disc 3 will be slower than 2, etc.
It's better to have the discs connected directly to the hub if possible.
Ali
What is the name of the EE BB plan are you on including its speed? What EE router & WiFi extenders do you have (read label or post a pix)?
Smart WiFi Plus package. Hub is SH31B and discs are 3x SW30A
Ali_A
@RGMS
Ali
RGMS
Thanks. The distance  between the hub and disc 3 is  about 30 m  - and the connection keeps dropping. Would upgrading to EE7 make a noticeable difference?
Ali_A
@RGMS
30m is the edge of range for the hub in optimal conditions, so that would explain the drop-outs.
Are you able to move disc 3 closer to the hub, without it losing range for users in the end location?
If not, you may want to consider an ethernet connection between Disc 3 and the hub. (The disc will favour wired mesh backhaul if connected via ethernet)
I can imagine you'll not want to run a 30m ethernet cable across the house, so you could look at using power-line adapters between the hub and disc 3, if your home electrical setup allows for it.
Once set up, you can verify the connection method by navigating to Advanced > Wireless > My discs in the Hub Manager. Just highlight the connected disc.
While Wi-Fi 7 could help, though ideally you may want to think about the possibility of moving the incoming Broadband connection to a location more towards the middle of the house, so your hub could be centralised? This would simplify your options, as well as future proofing your Wi-Fi signal throughout your home.
Ali
