Smart Hybrid Connect question re functionality.
grantp2
Just moved over to EE from BT and have received a Smart Hub Plus, a Smart WiFi plus and a smart Hybrid Connect.
So far they all seem to work though I have yet to check  broadband access to my NAS.
My question is about Hybrid Connect. I tested what happens if BB connectivity is lost. That seemed to work ok after a few minutes.
But what should happen when BB connectivity is reinstated?
Should things revert to the Hub Plus automatically? Or does one just continue to use 4G until one checks the Hub and discovers that it's started to work again? My test suggested the latter activity.
The User Guide does not seem to cover the subject.
When BB comes back the SH+ should revert back after a few mins.
