Security camera connection
StuartC4
I am  about to purchase an internal security camera , possibly a Tapo C210, to monitor a room in my house. My wifi is managed through a Smart Hub which I believe is dual 2.4 and 5 GHz. My question is will the camera connect automatically to the Smart Hub or do I have to make an adjustment in the Hub?
Peter_W
Welcome to the Community, @StuartC4
If you choose to purchase this and have trouble with the automatic network, it's also possible to enable Compatible WiFi.
This is a dedicated 2.4 GHz network that's designed to maximise your chance of being able to connect older IoT devices.
Peter
Maestro
Maestro
@StuartC4 you will not know that until you try the connection, all depends on how the devices play with the hub, securities or band control will be the ones to look at if not.
Thanks, I suspected that might be the case since some descriptions of the hub mention 'auto'! Nice to have it confirmed.
Peter_W
Peter
Northerner
Hi @StuartC4
You'll need to connect them in comparability mode but once connected they should be ok. I have a couple of these cameras (not on EE) and they work great.
You'll likely need to update the firmware and once reset i would recommend removing the power cable and reconnecting. Should be good to go.
StuartC4
Thank you everyone for your helpful replies.  In fact this was achieved much easier than I feared. All the connection were achieved automatically, no need to interact with router settings at all!
