Smart Hybrid Connect external antennas
NewportMichael
Has anyone used  external antennas to boost the 4G signal on the hybrid hub. I'm in a good 4G coverage area but signal is poor on the hybrid hub.
What are you basing the "good 4G coverage area" statement on? Are you using an EE phone in the same location, or something else?
Does the hybrid hub have any options for reading the signal measurements? dB levels, RSRP, RSRQ, SNR etc
Maestro
Maestro
@NewportMichael As @bristolian has kindly pointed out THERE IS NO good (( indoor )) 4G/5G signal area, it's all a load off tosh from any Area map that Any mobile operator will say, all you can do is try to either find where the best signal is within your home, or try doing your External Arial experiment, if you do go down that route find an local expert they will guide you best for type/location etc, and THEN be prepared to run an Ethernet Cable from the Hybrid to the Router as the expert will more than likely want the Hybrid and the Arial up in the loft as high as possible....
I said nothing of the sort. I merely enquired as to what the comment was based on.
@bristolian Sorry did not mean to say that you implied such, my bad reading it back.!!!!
