Smart Hub Pro much better over Smart Hub Plus
Profile closed
Not applicable
Just installed the Smart Hub Pro today and so far the set up experiance, range, speed tests have all been good, even VoIP connected without issue. The Smart Hub Plus was a nightmare, errors trying to get into the admin page and it was very sluggish and slow, wired devices taking 1-2 minutes to connect to the internet after the router had finished setting up, VoIP would just not detect your number and show red in the router admin page. So far the Pro has fixed all of thse issues. But I have seen a couple posts on here saying the Pro likes to randomly reboot itself between the hours of 00:00 and 00:30 so I'll update this thread if that also happens to me.
11 REPLIES 11
@Ewan15 You will more than likely find that the Ethernet port connection could be device specific, and that the switch is more just for elimination and speed buffering, 2.5Gb/s ports are up there and matching all 2.5Gb/s like for like will be way less of an issue, when you mix and match more likely to have problems.
Profile closed
Not applicable
My PC is plugged directly into the Smart Hub Pro using a 10 metre Cat6 ethernet cable, my PC motherboard only has a 1Gb ethernet port and the ONT I plugged the Smart Hub Pro into only has a 1Gb WAN port. The brand of the ONT is Nokia, we are on the 1Gbs package.
