‎20-04-2025 04:31 PM
How can I get the new Smart Hub Pro? I want to be able to have wifi 7. My only option appears to be creating a new contract (I've just recently moved from BT) but I don't want to do that at the moment.
‎20-04-2025 04:42 PM - edited ‎20-04-2025 04:45 PM
It can be added as an additional service for £10p/m, known as Smart WiFi Pro, if you are on a New EE Full Fibre connection of 150 Mbps or higher.
This will provide you with the Smart Hub Pro and a Smart Wifi Pro extender. You would then be able to request 2 additional units one at a time, if the initially provided extender did not offer sufficient coverage of the property according to the terms which I will link below.
You can read more in the terms and conditions here: https://ee.co.uk/help/terms-and-conditions/broadband/smart-wifi-terms-and-conditions
And the WiFi 7 info page here for features and specs: https://ee.co.uk/broadband/wifi-7
‎20-04-2025 04:43 PM
Hi @tmarsh12345
Just buy a third party system which will be much improved on the free isp router.
‎20-04-2025 04:47 PM
Yes that's the issue, who would pay an extra tenner p?m for something that new customers get free? I'm assuming that's the case?
‎20-04-2025 04:48 PM
Only new custs on the 1.6 Gig plan.
‎20-04-2025 04:49 PM - edited ‎20-04-2025 04:52 PM
New Customers do not get it for free, only those on the 1.6Gb Busiest Home Bundle or Broadband Made for Gamers.
New Customers typically receive the EE Smart Hub Plus which is a WiFi 6 unit, however the performance differential with the BT Smart Hub 2 is negligible at most speeds up to around 500 Mbps.
Important to note you're not just paying for the Smart Hub Pro, you're also getting the Smart Wifi Pro extender devices as part of the additional service alongside it's £100 guarantee for speeds of 100 Mbps throughout the property.
Have a read of the T&Cs I linked to if you want to find out more.
‎20-04-2025 04:50 PM
Thanks. I'm on 900 and 62 a month is already too much.
‎20-04-2025 04:53 PM
That's £39 pm to new custs. Are you including EE TV in your cost?
If I buy a WiFi 7 router is it just a matter of plugging it in? I've read that some settings need tinkered with.
‎20-04-2025 04:54 PM - edited ‎20-04-2025 04:56 PM
Is that on an Essentials, All Rounder or Full Works plan?
That may explain the pricing differential.
For setting up your own router, you would just have to populate the PPPoE credentials that you can find here: https://ee.co.uk/help/broadband/getting-started/using-and-configuring-a-third-party-router
Bear in mind EE cannot provide any support for your third party router, so if you have any issues with your connection you would need to plug back in the EE device if you need help.
