01-02-2025 03:29 PM
Hello,
I'm considering getting the EE Smart Hub Pro WiFi 7, but can anyone confirm if the wireless backhaul connection uses MLO, e.g both the 5GHz and 6GHz connections for the wireless backhaul?
Regards,
Liam
01-02-2025 06:07 PM
01-02-2025 04:49 PM - edited 01-02-2025 05:28 PM
@liamscor MLO is not wireless backhaul, but do believe that the Pro router and the Smart wireless try hard to use the 6Ghz connection as the backhaul when they are working hand in hand with each other. There was a wi-fi 7 posting with some MLO on it, will try to find and link below if found. Not finding much will keep checking. Just have to read and see if anything helps with regards to MLO operation, would think router MAY be up there by now, not sure if all functional trying that through smart wireless device connection. Final part link to info about the router, play close attention to antenna number.
Ethernet Ports on new Smart Hub Pro Not Working - HELP! - Page 3 - The EE Community
Smart Hub Pro: Hands On - The good, the bad and the ugly - The EE Community
01-02-2025 05:04 PM
@liamscor EE seem reluctant to show specs on their equipment recently. But ISP Review are a bit more forthcoming https://www.ispreview.co.uk/index.php/2024/09/ee-uk-makes-new-wi-fi-7-smart-hub-pro-broadband-router...
Seems yes.
01-02-2025 06:07 PM
Smart WiFi Pro Connects to the Pro Hub via a 6Ghz connection 👍
02-02-2025 02:36 PM
Hello,
Thanks @Mustrum and @mikefairgrieve for your responses, that is very helpful.
@JimM11 I must have got confused, since I heard that the new netgear orbi 770 uses both the 5GHz and 6GHz backhaul simultaneously using MLO where possible, so was just wondering if the EE Smart Hub Pro router was the same.
Anyway thank you everyone for your help.
Regards,
Liam
02-02-2025 02:50 PM
@liamscor For MLO 6Ghz is not a requirement, but all of this is dependant on what BOTH systems settle on and agree too.
What is WiFi 7’s Multi-Link Operation (MLO)? | TP-Link
02-02-2025 04:03 PM
