07-01-2025 05:56 PM
Does anyone have any recommendations for a wall mount for the smart hub pro?
06-03-2026
04:57 PM
- last edited on
06-03-2026
10:41 PM
Kh_timi
Try this one. You can get one for mounting the hub facing left or right. Much better for cable management.
It may be on Amazon too.
[Mod edit: Removed external link. Your product recommendation is really helpful - users can search for "Smart Hub wall mount" on eBay or Amazon themselves. Thanks!]
06-03-2026 08:40 PM - edited 06-03-2026 08:43 PM
Just to point out this thread is from January 2025 so I think it’s already being solved for the OP.
This also isn’t a place to advertise your own products. @Andrei_K Or eBay seller AK3D Studio if you prefer. 🤣
06-08-2026 05:06 PM
So I should recommend someone else's product? Lol))
06-08-2026 05:12 PM
@Andrei_K Yes you can is there a reason why not? Choices.
06-08-2026 06:36 PM
Sorry @JimM11, I should have used tags.. It was a reply to Chris_B comment, where it was mentioned that this is not the place to recommend a product if I designed it myself)
06-08-2026 06:39 PM - edited 06-08-2026 06:41 PM
@Andrei_K No problems. You may wish to look at the rules, well defined to the what and what not's, not a FREE advertising platform.
06-08-2026 09:55 PM
@Andrei_K By your link to your own item being moderated and thus removed. This isn’t a place to advertise your own products as I mentioned back in March this of this year. This is trying to advertise your own products for financial gain and by using this forum it can give the impression it’s got EE approval for this router. It’s a form of miss selling.
06-08-2026 10:51 PM
@Andrei_K : The Mod at the time just removed the link to your own site. They still left your logo & indeed complimented you on your product being useful to this enquiry.
There is no explicit Guideline banning advertising other products. Indeed we do it all the time when we recommend a bit of technical kit on Amazon etc. satisfying the needs of OPs.
