Smart Hub Pro Wall Mount
tel1969
Does anyone have any recommendations for a wall mount for the smart hub pro?
17 REPLIES 17
@tel1969  I’ve just searched Amazon and found THIS you’ll need to double check the width. There are others on there also
tel1969
Thanks Chris, done s search and found this which is a exact fit for the  Smart Hub Pro
https://amzn.eu/d/c60UDjU
@tel1969 How good do you find the wi-fi signal  and what kind of area coverage do you get where you have the Pro router placed?
Router was originally under the stairs as that’s where the line came in, so it was in a bad location. Putting on the outside  & elevated  greatly improved coverage & signal. Just drilled a hole in the wall & ran the cables direct from the BT fibre box into the  router
@tel1969 Thanks for getting back, you done a good job, very neat but was just wondering how good the signal was location wise, being in a corner like it is, but way better than being stuck in the cupboard no doubt for sure all about the position.👍👍
A better view of the position. Originally it was behind the door on the right
@tel1969  Happy you found the perfect solution looks good too.   My smart hub plus is sitting in a cupboard below my fish tank out of sight and luckily I have no issues with it there being below water as that’s not the best place a router can be located.
You might even be able to find a grommet to fit the hole just to tidy that up a bit.   But that’s just the sort of thing I’ll do as it would bug me.   Something similar to this.
https://amzn.eu/d/c1qlCCv
Thanks for the link, that’s perfect! 👍
alin1989
This is the best option I found at the moment, I'm very happy with it.
