‎16-05-2024 11:36 AM
Just thought it might be worth putting up a list of all the firmware rollouts for the Smart Hub Plus SH31B Router that have happened in the past year or so to see if this adds/removes functionality or fixes/introduces any bugs to the routers.
Last night mine updated to r1.34.1-R-1055417-PROD-83002 and with this firmware update the app version was unchanged.
Changes:
‎27-06-2025 01:34 PM
Yes, @bobpullen ,
You can control what your kids see online in your Settings in the new EE app. Don't have the app?
Download it now
is a repetition of the Parental Controls section above it.
‎03-09-2025 01:57 PM
Today (03/09/2025) my Smart Hub Plus updated to:
It seems this has added some new functionality to connect to the hub over HTTPS using a self-signed certificate.
‎03-09-2025 02:19 PM
@smneal Is http still working at all or a redirect to only use https.....
‎03-09-2025 02:32 PM - edited ‎03-09-2025 02:33 PM
@JimM11 There seems to be a redirect to HTTPS
‎03-09-2025 02:39 PM
@smneal Thanks for the reply, HTTPS has to be used web address now and security cert has to be installed!
‎10-10-2025 10:37 PM
Today (10/10/2025) my Smart Hub Plus updated to:
‎11-10-2025 07:35 AM
@Huggons1 The Pro and the Plus now reach unity with each other not 100% sure that https is used on both now....
FW: r3.8.24-R-1531355-PROD-1 and the gui is at App version 3.1.3. 17/09/2025 Now https:// For the EE Pro version
FW: r3.8.24-R-1531355-PROD-83002 and the gui is at App version 3.1.3. 10/10/2025 Now https:// For the EE Plus version
‎11-10-2025 10:44 AM
‎11-10-2025 10:54 AM
@bobpullen Thanks!
‎05-12-2025 11:31 AM
Smart Hub Plus Firmware update 05/12/2025
r3.8.30-R-1627300-PROD-83002
App version 3.1.18
