Smart Hub Plus SH31B Router Firmware changelog
monitorcurve
Just thought it might be worth putting up a list of all the firmware rollouts for the Smart Hub Plus SH31B Router that have happened in the past year or so to see if this adds/removes functionality or fixes/introduces any bugs to the routers.
Last night mine updated to r1.34.1-R-1055417-PROD-83002 and with this firmware update the app version was unchanged.
Changes:
41 REPLIES 41
monitorcurve
Just had another firmware update pushed out in the early hours of 28th January 2025
App version: 2.36.4 (unchanged)
Firmware version: r2.68.16-R-1296172-PROD-83002
@monitorcurve That will be an update to fix the update on the previous couple weeks ago, coming thick and fast to you at least.
monitorcurve
Updating with another firmware update pushed out in the early hours of 15th February 2025
Firmware version: r2.68.18-R-1303195-PROD-83002
@monitorcurve At least looks like you got to skip the r2.68.17 version and straight from 16 to 18.
monitorcurve
New firmware update on 11th April 2025 in the middle of the night
App version: 2.36.9
Firmware version: r2.72.3-R-1302579-PROD-83002
I did notice that there were a bunch of devices in the device list that had lost their names that were previously set in the EE app, and these needed to be re-saved in the EE app.
monitorcurve
New firmware update on 23rd June 2025 in the middle of the night
App version: 2.36.9 (unchanged from above)
Firmware version: r3.8.11-R-1414606-PROD-83002
All these firmware changes and yet they still can't make it so you can change the names of devices in the router page like every other router 😠
Huggons1
Wouldn't it be nice, if they produced release notes for the firmware updates.
@Huggons1 One could only hope, but you know it's not going to happen! Rely on the customers going out to check yes never fixed this, that also, wait a minute forgot about that, oops was working so broke that! Where's the fun!
@monitorcurve Can i ask a favour off you if/when you get sometime, could you see if the Router is transmitting the EE WiFi ssid from yours, have an OP swears that he is on the + and can see the ssid EE WiFi that was never done before on that hub!
Hi @JimM11, not @monitorcurve but my EE Smart Hub Plus did an update today and is now broadcasting the EE WiFi SSID. I’ve connected and can confirm the SSID is usable.
