24-07-2026 11:47 AM
Hi Could anyone shed some light on a problem i am having with our Tapo security cameras ?, ever since we upgraded to the EE smart hub 7 it keeps disconnecting them from the WiFi and wont let them reconnect, we have tried contacting EE and they blame the cameras but having contacted Tapo they say there is no problem with them, we have tried several different makes of camera but they all do the same I.E they will stay on maybe a day or sometimes less before disconnecting and none of them will re start back onto WiFi, we never had this problem with our other BT router before we changed to the EE one but EE wont have this they say it should still work the same, we have also tried changing channels and to compatibility mode but still have the same problem, any help would be gratefully received.
Thank You G
24-07-2026 07:00 PM
Thank you every one for your in-depth replies you have been most helpfull
24-07-2026 12:27 PM
@Grandalise : Sometimes older or weaker devices may not be compatible with the default WiFi settings of EE Smart Hubs. Try setting up Compatible WiFi on the router under Advanced > Wireless Settings > Config > Compatible WiFi (it defaults to 2.4 GHz only & WPA2) & connect your problematic 2.4 GHz devices to that.
24-07-2026 01:22 PM
Thank you for your reply.
i have already tried that on all the cameras we tried but still wont stay connected, its like the router finds the camera and disconnects it after a while
24-07-2026 03:26 PM
I have tried changing wifi chan between 1-6 and 11 on compatibility mode, I have tried taking smart mode off, every time they cant connect i change the wireless channel and they reconnect but they turn off after several hours again but every time i change the wifi channel it lets them re connect for a while then same problem occurs
24-07-2026 04:39 PM - edited 24-07-2026 04:40 PM
@Grandalise Have a look at WHAT FW Firmware you Pro hub is on currently, the App will show you details if it is working.
EE Hub firmware versions - The EE Community
24-07-2026 05:42 PM
@Grandalise Have copied the last few that got posted up bottom off the thread for you.
FW: r3.8.24-R-1531355-PROD-1 and the gui is at App version 3.1.3 17/09/2025 Now https://
FW: r3.8.25-R-1595997-PROD-1 and the gui is at App version 3.1.3 23/12/2025
FW: r3.8.26-R-1595999-PROD-1 and the gui is at App Version 3.1.3 24/12/2025
FW: r4.28.1-R-1882725-PROD-1 and the gui is at App Version 3.14.5 31/05/2026 Stability Problem
24-07-2026 05:44 PM
thank You for your reply,
my firmware is R3.8.26 so how do i update it to more recent ? or have i to wait until it does it its self ?
24-07-2026 05:48 PM - edited 24-07-2026 05:50 PM
@Grandalise The one you have is good and not much strange with it, the update afraid is a wait until EE get round to doing what they expect FW wise, you don't want the last one on the list currently... EE published but not happened as yet with anyone posted otherwise.
Firmware version: r4.29.1
Deployment date: From June 2026
Hub Type: SH40J
Release notes:
24-07-2026 05:58 PM
Thank you for your reply, Its a pain when you try everything you can think of to sort it out, im only in a bungalow so wifi shouldn’t be a problem i have even tried with the wifi extender that came with the router and still no joy we are quite savvy with computers ect but this has us stumped, it just has to be the router
24-07-2026 06:02 PM - edited 24-07-2026 06:13 PM
@Grandalise Honestly if you have a BT Smarthub2 version stick it back on the connection, EE are having a somewhat torrid time just now with all the EE FW updates, and the fixes although fixing the issues they created, are now showing cracks in the woodwork again.
Look closely at the spec off the devices with the issue, and if WPA2-Personal is as good as they get, then off the Main wifi instantly get the Comp setup making 100% sure it's all set WPA2-Personal and then redirect them to the new SSID with the -Comp that gets fired up. If you ever have a look at the Pro router with a wifi analyser you will see there is a lot going on with all the bands and the hidden ssid's that you may/may not be able to see.
