Send emails from btinternet.com account when using third party broadband
MartinEllis
I switched broadband provider to Voneus in April 2025. I still have an account with EE (and am under contract until late 2026). I aim to use my btinternet.com email account until my contract with EE expires.
If I try to send emails from my btinternet.com account whilst connected to Voneus broadband, I get various error messages:
Unable to verify account name or password.
Can't connect to the account : "my btinternet email address". Enter the password for user "my btinternet email address".
My outgoing SMTP settings are:
Outgoing Mail Server: mail.btinternet.com
Port: 465
SSL encryption: Enabled
Authentication: Password
When I connect using my existing EE router, I can send emails from btinternet.com without any problems.
I can still access my email via webmail (on a browser).
Can anybody offer me any advice? Many thanks.
@MartinEllis Try port 587 see how it goes.
SMTP Settings for BT Internet Email
  • Outgoing Mail Server (SMTP): mail.btinternet.com
  • Port: 587 (for TLS) or 465 (for SSL)
  • Encryption: Use SSL or TLS (recommended for security)
  • Authentication: Required
  • Username: Your full BT email address (e.g., [email protected])
  • Password: Your BT email password
42 REPLIES 42
Do you have the identical SMTP server settings on both EE & Voneus BB
Are you sure the Encryption is just SSL & not STARTTLS?
MartinEllis
This is a screenshot from the Apple Mail Outgoing Mail Server setting. I assume this is the same for both EE and Voneus (as I'm using the same email client (Apple Mail) for both).
Mustrum
@MartinEllis
My settings are
Port: 993
Encryption method : SSL/TLS
this works fine for 365 mail, but may differ depending on the mail client you are using.
There are more details on the BT Site https://www.bt.com/help/email/manage-email-account/manual-settings/what-are-the-settings-for-outgoin...
Not STARTTLS
Hope this helps.
If you've got these settings correct it can only be that you have "your btinternet email address" or "your btinternet email password" wrong under Voneus but not EE.
@Mustrum : Port 993 is for the IMAP Server, not the SMTP Server.
@MartinEllis   I don't have it set up on my iPhone or iPad, but try port 993
If I change the port to 995, the error message above appears (if I'm connected to either Voneus or EE). However if I change the port back to 465, there's only a problem if I'm connected to Voneus. It works fine when connected to EE.
@MartinEllis   what about port 993 ?  or was that a typo?
Thank you but the email address and password details are identical for both. I've not changed anything or entered anything separately.
