Ring doorbell
yt5754
I have just upgraded to EE fibre and my Ring 3 plus doorbell won't connect to the new network.
Has anyone had the same problem?
16 REPLIES 16
I had a problem connecting my ring doorbell after the 2.4 and 5.0Ghz on my white router were split for me by EE.  I saved the settings after the split.  I then turned off the 5.0Ghz band and set the 2.4Ghz band to channel 1.  I then tried connecting the doorbell and it worked!  I then restored the settings to get the 5.0Ghz band back and it all stayed working.  So far so good
@IanC14 : Yes, that's the way to do it! EE can't split the bands remotely.
PF76
Yes, I'm having the exact same problem. Very frustrating
Droseveare
It's because EE router keeps moving it's IP address I had to use a old BT router and then it worked ok
@Droseveare Running fine with EE Smarthub+ no issues on Ringdoor bell, have made IP static and always been this way. Your observation may be correct who knows, but Ring Doorbell/Cameras can be the most awkward at times to get on the wi-fi signal as also other devices.
Same problem here. I switched the 5ghz to 2.5ghz then all my other devices in the home including tv and laptops ground to a slow sluggish pace/tripping and protesting against it!
it’s a no sence
I don’t want to buy another doorbell!!!!!
argggh
@Cosmicgirl : You should only temporarily disable the 5 GHz band while connecting problematic 2.4 GHz devices. Then you can switch it back on again.
