on 16-06-2026 09:43 AM
Are EE still working on the fix RE smart devices dropping off line?
We have done all the resets and router settings (compatible, channel 6 etc), however over the last few days, just when we thought it was sorted, everything is off line again.
Very annoying, we are paying a lot of money for broadband & we shouldn’t be having to log into a router hub checking/changing settings.
on 16-06-2026 12:14 PM
Hey there, @SR2026
We do have an existing thread about these issues, but I can feed back that you've been affected.
Which model of EE Hub are you using at the moment?
Peter
16-06-2026 02:40 PM - edited 16-06-2026 02:42 PM
@SR2026 Ideally yes there should be no need to do the checks, you say RE is this a third party device you have connected to the system? FW is rolling out again as confirmed in another post so you are aware. Not able to look back as nothing is posted against your ID, so not sure if you are Pro or Plus affected Hub?
on 16-06-2026 02:52 PM
Thank you. Smart Hub 6 plus.
This is the first time I have ever posted a thread so I’m new to this!
16-06-2026 03:12 PM - edited 16-06-2026 03:13 PM
@SR2026 No problems. your hub is updating now so worth a look see were it's at version wise. From and too below.
FW: r4.26.1-R-1860948-PROD-83002 and the gui is at App version 3.14.5 25/05/2026 OP Posted Stability Problem
FW: r4.26.3-R-1923144-PROD-83002 and the gui is at App version 3.14.5 12/06/2026 OP Posted
