Review of WiFi 7 Pro Router & 1.6Gb Service - Mixed Feelings.
CarbonStar
Hi Everyone!
Please see my review below,
1). Engineer Appointment was 8am-1pm and the gentleman arrived around 9:15am and gave a courtesy call 10 mins before too!
2). Swapped the little ONT box within 5 minutes, just took off and added new one - turned everything on and started working!
3). Gave the Hub Pro a few minutes and was hitting max speed!
4). My iPhone 16 Pro Max is able to get around 1.4Gb download max from the hub, up from 840Mb from my Eero 6E router (TalkTalk).
5). PC is almost at 1.7Gb Down with Ethernet.
6). Disappointing to see you cannot hide your SSID / not Broadcast Your Wifi Signal - but it is what it is I guess.
7). Not sure if I need to opt out of "EE WiFi" which makes you a public WiFi hotspot? - can anyone advise on this please?
8). Overall, higher latency on EE than TalkTalk but much faster speeds - not sure if I'll keep or switch back as Latency is more important than Speed to me. Disappointed in this - EE has 2-4x more latency than TalkTalk - I will see if this will settle over next 24-48 hours.
9). Furthest Room in my home (3-storey) gets 600 - 700Mb which is excellent. The same spot with Virgin Media (1Gb) would get 150 - 300Mb using their router and wifi booster in the same location as EE's Pro Hub and Extender. I appre you don't need such fast speeds however for battery life, the quicker load times and stronger signal I'm hoping will help!
I think that's everything, so conclude,
Great Speeds, Easy Set Up.
Higher Latency - most important for me - so I will most likely cancel this and go back to TalkTalk.
64 REPLIES 64
Hey
It’s just really stable, everything connected. 0 dropouts. The TP link was only connecting to half my devices. Also to my surprise the speeds were super slow- half of what I was getting off the EE mesh
@Pras1011 wrote:
to buy the EE WiFi Pro SW40J to mesh with my EE 5G Hub HH70C.
But will it?
Pras1011
There is only one way to find out!
@Pras1011 : Yes, probably the only way!
EE are supplying their latest smart routers & WiFi extenders as companion pieces that work with no other.
Pras1011
I am getting mine very soon to confirm this.
