Replacing EE Smart Hub with DECO
khmatheson
I am trying to replace my EE smart hub with a pair of DECO S7 units.
I have FTTP, so want to connect the DECO to the ONT
On the DECO app, it’s asks for my broadband username and password - where can I get this from?
@XRaySpeX ???
You may use either as long as you get the pwds right to go with them.
If the EE Username is PRODUCTIONHQNUN*********@FS, its pwd is HQNPASS********* . The BT pwd is BT.
URGENT: Obscure the digits in your EE Username PRODUCTIONHQNUN*********@fs from this public site.
6 REPLIES 6
Mustrum
@khmatheson   have a look at this Help page, it should have everything you need, but shout up if you need more info.
https://ee.co.uk/help/broadband/getting-started/using-and-configuring-a-third-party-router
@khmatheson   you can use either. Do you have the password for the PRODUCTION username?
There is a help desk page that helps you work it out, and is a shortened version of the username, but not sure where they moved it to!
Thanks, I just left the password section blank and it seems to have worked???
Yeah! 'BT' or blank.
