12-04-2022 07:53 AM
I have just recently renewed by broadband contract. It was OK, but not perfect, before. Since then it has become worse and even non existent regularly. Considering breaking my contract for non provision of service, a breach on the part of EE. It seems that EE are not even interested.
12-04-2022 09:08 AM
