Reduce Smart Hub Home Phone Adapter Light
rphone
Hi, I have just set up the EE Home Phone Adapter and connected it to the Smart Hub.  The Adapter has a very bright light.  Can this be dimmed or turned off?
@rphone Not a controlled or access device, put some opaque tape over the LED to dull it down, or black tape if you do not want to see it. Will also copy below what the led does, just got to go get it from the Digital Home Phone section.
Edit: Added.
What your Digital Voice
Adapter light means
1 On initial plug in – flashes 0.5 seconds on,
2 seconds off
2 During registration – flashes quickly
0.5 seconds on, 0.5 seconds off
3 Once registered – stays solid green
4 During a call – flashes slowly 1 second on,
1 second off
5 Once registered, if there’s a connection
problem with your broadband – flashes
0.5 seconds on and 2 seconds off.
Maximum Digital
Voice devices
You can register a maximum of 5 Digital Voice
devices (that includes Digital Voice Handsets
or Digital Voice Adapters) to your new Hub at
one time
Profile closed
Not applicable
Don't have the Home Phone Adapter, but the Hub and Extender lights can be dimmed/turned off.
Is there nothing in Hub Manager or the app?
Can't see an option for the Home Phone Adapter (I do see the options for the Hub and Extender lights).
Edit: Added.
Adapter light means
2 seconds off
1 second off
Maximum Digital
Voice devices
one time
