Recommendation's for home printer on Wi Fi 7 with Smart Hub Pro Router.
LHofR
Northerner
Hi @LHofR
Any printer will connect but only you know what you want, printer, black & white, colour, built in scanner etc.
Just watch out for subscriptions to ink.
LHofR
Thanks, I currently have a HP Envy 120e All in One that won’t connect. I have been told due to its age, it will not operate, unless I change settings on the hub, which could affect performance & security etc. which seems pointless as I have just upgraded. Any thoughts would be helpful.
Northerner
Hi @LHofR
Connect your printer via the cable to your laptop/PC and use the HP app to connect to WiFi. Once done it should work ok. Have you tried this?
No, just been trying via wireless wizard with router passkey. Will give it a try. Thanks.
Me too. I guess, I will just have to buy a new printer
