09-12-2022 02:30 PM
I am in the same situation.
Yesterday 900mbps was installed and router not come because was send used ROYAL MAIL.
So i using my own router with login and password from old fibre EE router. But i am not happy because on begin speed was over 900mb/100mb (dl/ul) and from 10am is just 40/10
Courier Tracking Events for MQ_hiddennumbers_GB | |||
Date | Time | Incident Description | Location |
This parcel has been tracked using Royal Mail Extended tracking, therefore the first entry (highlighted in green) is the latest major status update which will be shown publically to the recipient if they track their parcel at www.royalmail.com. | |||
06/12/2022 | 21:41:01 | We have your item at Northampton Peak Parcel Hub. | |
06/12/2022 | 21:41:01 | Item Received | Northampton Peak Parcel Hub |
05/12/2022 | 17:08:16 | Sender despatching item |
11-12-2022 06:29 AM
Nevermind 🤔
On Saturday just before 6pm, the router from EE finally arrived.
Result:
https://www.thinkbroadband.com/speedtest/1670739897160829155
09-12-2022 02:45 PM
@AndrewG : Welcome to EE's Home Broadband Forum.
1. Try a wired speedtest, using an Ethernet cable supplied with the router, here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
2. What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker, not the Postcode Checker.
09-12-2022 10:20 PM
1. https://www.thinkbroadband.com/speedtest/1670623787360910755
2. (Don't have landline).
58.6 | 44 | 18.8 | 12.4 | 39.8 | Available | Available |
57 | 40 | 18.3 | 11.1 | 35 | Available | Available |
Up to 1000 | Up to 220 | -- | Available | 1 Stage |
Up to 3.5 | -- | 2 to 6 | Available |
Up to 3.5 | Up to 0.5 | 2 to 6 | Available |
Up to 2.5 | -- | 1.5 to 5 | Available |
1 | -- | -- | Available |
Up to 3.5 | -- | 2 to 6 | -- | -- |
Up to 2.5 | -- | 2 to 6 | -- | -- |
Up to 1 | -- | 1.5 to 5 | -- | -- |
Available |
Available |
N |
N |
Y |
09-12-2022 11:11 PM
@AndrewG : That doesn't look like EE Full Fibre 900 (FTTP); more like EE 40-Meg Fibre.
Do you have an ONT there, a box on interior of outside wall, that you connect your router to by Ethernet?
Do not restart your router to do this test:
Post your full router stats:
10-12-2022 10:43 AM
@XRaySpeX wrote:@AndrewG : That doesn't look like EE Full Fibre 900 (FTTP); more like EE 40-Meg Fibre.
@XRaySpeX wrote:@AndrewG : [...]
- For a BrightBox: login and go to Advanced Settings > System > DSL Status. Also post 'System Uptime' from top of System Log page.
- For a SmartHub: login and go to Advanced Settings > Technical Log > Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
- For other routers: login to it according to the label on it as the admin user & navigate looking for its router/connection statistics.
Like i am mention in my first post, am using my own router with credentials form old EE router (year ago i have EE broadband).
My own router Asus DSL-AC68U is connected by WAN.
10-12-2022 12:30 PM
Those are not the figures I'm after. Those are all Settings. I'm after the resultant connection status. Is there a page with Connection/Data Rate/Speed on with perhaps the word "attenuation"?
What are all EE's estimated speeds which you'll find in your MyEE for BB under "Your BB speed"?
11-12-2022 06:29 AM
Nevermind 🤔
Result:
11-12-2022 06:51 AM
Funny that the ASUS could nowhere match this performance.
11-12-2022 08:00 AM
Asus DSL-AC68U is very old. I will check Asus RT-AX86U soon... 😉
11-12-2022 12:03 PM
I'm still waiting on my router and it's stuck at the same place as yours since 5th... they billed me too n I have no Internet. I tried a talk talk router but it doesn't get Internet I'm guessing because of different provider settings.
Dissapointed too
