08-12-2023 04:18 PM - edited 08-12-2023 04:18 PM
I've also just picked a sw10a from ebay and I can't get it to connect to my ee router via wireless or via cable, did you manage to get yours working?
09-01-2024 11:07 PM - edited 09-01-2024 11:44 PM
It looks like the same back as the EE Smart WiFi (2023) of Setting up Smart WiFi . Perhaps you need the EE Smart Hub (2023) of Set up your Home Broadband EE Router to go with it? Believe its model no.is SH20A.
08-12-2023 05:50 PM
Good evening, I've picked up a new smart wifi extender (Sw20A) From ebay and I can't get it to connect to my smart router either via wireless or wire. I've looked online and there doesn't seem to be much info on it. I've followed all instructions/guides and still can't get it to work. All help is much appreciated.
09-12-2023 11:35 AM
@Rolystaxi : Do you have the white Smart Router? The new white Smart WiFi Plus is intended for the black Smart Hub Plus.
09-12-2023 11:53 AM
Hiya, thanks for the reply, yes I have the white router. Is there no way it will connect? Or can I call ee and get a black router?
10-12-2023 09:33 PM
Good evening, I'm trying to find out what the model number is for the black smart hub plus. As I want to use the white smart WiFi plus with it as it doesn't work on my white router. Thanks in advance.
10-12-2023 09:46 PM - edited 10-12-2023 09:46 PM
Model nos.:
09-01-2024 11:10 AM - edited 09-01-2024 11:13 AM
Afternoon all, I've got the white ee WiFi extender (sw10a) what I want to know is what model number router do I need to ask for to use with this extender. I've read it's possible that I need the SH31B hub. Any help would be much appreciated.
09-01-2024 04:56 PM - edited 09-01-2024 04:59 PM
@Rolystaxi : Please post images of your router & of the WiFi extender so we can nail down just what you've got.
09-01-2024 05:16 PM - edited 09-01-2024 05:18 PM
I already have the SW10A as I thought it would work with my current EE router but it don't so I'm looking at getting the SH31B as was told thats the router i need to be able to use the SW10A
09-01-2024 05:28 PM - edited 09-01-2024 05:37 PM
Now please post an image of your current EE router.
Where did you get a Smart Hub Plus (SH31B) if it's not yours?
The Smart WiFi (SW10A) is not compatible with the Smart Hub Plus (SH31B). For that router you need the Smart WiFi Plus (SW30A).
