Question about the power supply to my Hub please.
Marg0105
I need to disconnect the power to my hub for a few seconds. ( one minute max) I am concerned/scared in case it doesn't start again as I depend on it.
How likely is it to reconnect and work as it is doing currently please?
I have fibre to the premises and the hub is about 9 months old.
I tried to ask by phoning EE but just got diverted to an automatic text based system.
Thank you
It will connect up again almost immediately as long as you don't keep doing it frequently.
Minkey1
Star Contributor
Star Contributor
Marg, I had to fit a new downstairs socket yesterday so that meant turning the power off that circuit, which includes the router. Turned power back on after and the router re-connected fine, as I expected it to do.
Should be no problem. If there is, come back here some other way, maybe a phone on 4/5G if you have one, or a neighbour.
Mike
Ex BT. Now EE Fibre 900 via SH+ with 2 Extenders, EE TV Pro & Mini boxes, 2 EE SIM's only in iPhones 17PM and 13.
LG Oled, Denon/Cambridge Audio 7.1, Panasonic 4K player, Apple TV 4K
Marg0105
Thank you Minkey1 and XRaySpeX for your prompt, helpful & encouraging replies. It will be a one-off.
Love how you have listed the kit you are using 😀
Marg
