24-07-2023 10:28 PM
I've been trying unsuccessfully to open some ports that are required for a game from my PC.  I've recently changed from BT Smarthub 5 to EE full fibre but the basic router functions are the same. I've added a rule for ports 2302-2303 internal and external, and set to UDP/TCP. I've selected the machine I'm playing on. When I check any port checking website, it says they're closed, and when I check ShieldsUP! it states everything is stealth.
I have even gone so far as disabling the router firewall and windows defender firewall, and the ports still show as closed on websites including on ShieldsUP!, although while the rest of the ports show as stealth,  the two ports that have rules show as closed in this scenario.
I do have a DDNS entered on the router, could this be relevant? At this point I'm at a bit of a loss.
24-07-2023 11:38 PM
@charliereddog : What type of server is meant to be running on these ports & is it up & running?
Can you test it w/out DDNS using its current public IP?
24-07-2023 11:40 PM
Hi, it's not a server, but my desktop pc. It's just a couple of ports that need to be open to run ArmA3 if I'm hosting the game. I've tested using the DDNS and the IP, same results with both.
24-07-2023 11:47 PM - edited 24-07-2023 11:47 PM
Are you trying to connect to an ArmA3 game being hosted somewhere remotely or are you yourself running an ArmA3 game on your PC that you want remote others to connect to? The latter is a server.
24-07-2023 11:59 PM
As I said above, I'm attempting to host.
25-07-2023 12:09 AM
Ah, so you did. Then that's a server running on your PC. Post your Port Forwarding Settings.
25-07-2023 12:11 AM
There is some conflicting info out as to which ports need to be open, hence why I'm doing the range to 2306.
25-07-2023 12:20 AM - edited 25-07-2023 12:31 AM
That looks OK
As a test can you try to connect to it internally from your LAN?
25-07-2023 12:31 AM
Not sure how I'd do that? Do you mean connect to ArmA? If so, no as I don't have another device with it on.
25-07-2023 12:34 AM
No, I mean connect to your hosted game from your PC as if you were a player connecting to it remotely.
