on 17-04-2025 11:07 AM
I've recently changed from BT hub (which worked fine) to EE hub and now have problems with security cameras. Specifically with a Panasonic Home Network security system. I've tried to connect under UPnP which is switched on in the EE hub, though the Panasonic mobile app says it probably isn't. Or trying to set up Port Forwarding doesn't so far work either. I can only connect through the EE hub in my house, not remotely. It just worked with the former BT hub. (I seem to have similar issues with a new wireless ADT system - for the moment that's their problem to sort out).
on 17-04-2025 02:51 PM
@Richard2953 which broadband service do you have and which router?
If you can, use the BT Router, they may want it back, but you could speak to CS and arrange to keep it.
on 17-04-2025 03:09 PM
It's designated as a Smart Hub 32B. Service is full fibre 900/110. BT does want theirs back. ADT visit next week so depending on what they say, I might send the EE hub back and keep the BT one.
17-04-2025 05:41 PM - edited 17-04-2025 05:45 PM
Why do you think you need Port Forwarding or UPnP? Panasonic System Setup Guide Home Network System HUB makes no reference to them as a requirement. I can successfully view remotely my security cameras which are an EE FF BB connection w/out the need for Port Forwarding.
If you are trying Port Forwarding what ports are you attempting to forward?
on 17-04-2025 06:03 PM
I didn't think I did need it - and I am no way an IT expert. As above, connections work fine at home when connecting direct to EE hub, but never connects when mobile is remote from home. I simply followed this advice from Panasonic to set up port forwarding as an alternative to relying on UPnP, but still can't get a remote connection.
on 17-04-2025 07:20 PM
OIC. There are reports that uPnP is broken on SH+. So show us your Port Forwarding settings.
on 18-04-2025 11:08 AM
The forward port numbers were as Panasonic gave - A B C as 62000, 62001, 62002 - which means nothing to me. I just input them. The EE config is below - I don't really know what I should have input for external and internal ports, or protocol (I assumed TCP).
on 18-04-2025 11:27 AM
Let's see it filled in. Don't forget to hit the '+' afterwards & Save it. Then show us what you end up with.
Usually Internal = External Ports, Protocol = TCP/UDP..
on 18-04-2025 03:06 PM
Like this
18-04-2025 04:24 PM - edited 18-04-2025 04:27 PM
You haven't pressed the '+' & Saved. They should then appear with a red "X" against them for when you want to remove them again.
I also think you shouldn't be leaving 1001 ports open but instead do 3 rules of 1 port each.
