Port Forwarding issue on Smart Hub 7 Plus
PeterAF
I'm trying to get faster download speeds for remote access to my Synology NAS. I've configured port forwarding on the Smart Hub 7 Plus but it still shows closed when checking. Synology say the ISP could be preventing this if they use Carrier-Grade NAT (CGNAT). Does anyone know if EE/BT use this?
Maestro
Maestro
@PeterAF They do NOT!
Thanks!
Any suggestions as to why port forwarding config doesn't work?
@PeterAF You have something wrong may be... Have a read on the link below!
Smart Hub 7 Plus Port Forwarding Issue - The EE Community
Thanks. People seem to be having a lot of troubles with this!
I'm on r3.35.24-R-1648110-PROD-84001, which I believe is latest FW, from your other post.
Can't see a solution in that thread?
btw - I don't get error messages; it all looks good in the rule and saves OK. NAS has Static IP.
@PeterAF You certainly are on the latest, have you tried the off for 5 minutes on the hub?
Then the Factory reset option that is just so not advised so you have to think carefully where you are on the cycle to re-input and specific values you may need!
